I've had this discussion with several others who've told me they actually found bits of corn shuck in the bottom of their tank when cleaning it out. While I have seen, for myself, damage to rubber parts relative to fuel systems I have a hard time grasping the corn shuck story. My brother runs an oil jobber that supplies about 35 gas stations in west Georgia and I've done some riding with his trouble shooter. Way too many filters in place to let anything visible through much less a corn shuck. But as stated above ethanol is an organic mixture that DOES absorb moisture. This has caused a very expensive headache to those who have to deal with it. Down here there are sensors in place that measure the moisture content in underground tanks ( and above) that will shut them down automatically. This moisture is what causes the problem when it is allowed to sit. The longer it sits the more it sucks up causing rust to form. I also had a 1989 Chevy van that ran like a dream for 8 years until 2005. I had it for 8 years. It acted like it was running out of gas. Two VERY good mechanics couldn't
find the problem. I pulled the tank again to check the fuel pump, again. I found the hose going from the filter sock to the pump had tiny holes that could only be seen when it is bent. My mechanic looked and said " Ethanol". Thanks to our wonderful GOV and EPA we will soon have E20. They will not "force" you into an electric car, you'll buy one cause your dino burner doesn't run. With coal power plants being shut down the juice to charge these cars will go through the roof. Solar is a great idea until the batteries blow your house up or start piling up in landfills. Some say wind mills kill birds, I say it weeds out the dumb ones. Someone in 2007 publicly stated "Under my version of a cap and trade plan electricity prices will necessarily skyrocket". Any guesses?
