Fish
I am a little slow this time of year so only doing 50 yards a week right now.
Mower, blower, trimmer, edger, pole saw,
Did you get any of that snow?
Hi group,
If you want to have a looksee at what's happening in Commercial Mower news look here:
Offering Propane Equipment and Conversions - Green Industry Pros
And here:
More mowers turning to propane fuel | CharlotteObserver.com
If you have any questions give me a holler...
1. Propane burns cleaner.
2. Propane is a domestic fuel.
3. Propane is up to 60% less expensive than gasoline.
5. Propane has 21% MORE power per pound than gasoline.
6. Propane is a minimum 107 octane.
7. Oil changes can be extended up to 3 times.
8. Propane contains no ethanol.
9. Propane doesn't go "bad" on the shelf.
10. Propane can't be stolen.
11. Legislation (see urls above) is coming to limit the use of gasoline for commercial mowing.
12. Many customers appreciate the efforts to reduce your carbon footprint.
13. Many municipal customers will accept the bid for a "Clean/Green" supplier over polluters.
14. Almost all HOAs will do business with a "Clean/Green" supplier because they are less polluting and quieter.
15. Fewer complaints from employees about emissions.
16. Much easier starting with propane.
17. No annual carb rebuilds with propane.
18. The conversion equipment can be transferred to a new unit.
19. Mowers last up to three times longer with propane.
20. Used units are worth more at resale because the engine has substantially less wear.
I'll stop at Twenty. There are many more not the least of which is "just wanting to do the right thing."
I'm curious, how many mowers did you run on propane? I'd really like to hear of your experience with them.
Regards!
How's this all working out with propane approaching $7+/gallon?
I think the main issue is cost I know it is way better but the conversion cost should be more practical.. if you are going to spend that much it would be better to buy equipment already setup for propane. I wouldnt go out and buy a new mower just to run propane so the cost of the conversion should be cheaper. If they want us to (just wanting to do the right thing) they need to step up on their end with the cost.
So if I understand this correctly it would be cheaper to buy a new mower and have it converted to propane or to buy one already set up for propane.
Anybody paying $7/gallon should find a new supplier. Mont Bellvue is $1.51.
