Know what you mean, being a parent takes a lot of time out of your normal daily chores.
We had temps in the high eighties, the grass was dry at 2:00 pm. I edged, mowed, string trimmed and blew the grass off of everything by 3:30, about ten minutes later it started to rain, I made it, my wife was very happy that I completed the whole process in less than two hours, but not as happy as I am.
I normally take two days to do the yard, 2 hours one day and 1.5 hours the next.
I actually felt comfortable enough to mow at the full eight mph and the mower did great, I did about six passes at that speed then I slowed back down.
I still haven't gotten used to the controls because I left six or seven digits in the lawn from not turning the mower correctly.
I found that just backing up at the end of the row then proceeding forward again is the easiest and doesn't mess up the grass.
I have no problem driving around with the engine is running at 1/4 throttle, but when I open it up to mow then everything is much more sensitive.
I'm still glad I picked this one, I do have a little problem on the incline in the front yard, I could use another two hundred pounds on the rear wheels, maybe I can find some wheel weights.
I think this will all change when the ditch dries up.
