VegetiveSteam
- Jun 1, 2022
- 0
- 368
Hopefully the new ignition modules take care of it but just FYI, you'll have to find either a used one or someone with old stock as that 24 584 09-S spark advance module has been NLA for 5 years or so. The current fix is a conversion kit that includes a new flywheel and two new ignition modules designed to work with the timing difference of the new flywheel versus what is on your engine now. If needed the part number for that kit is 24 755 308-S and is about $30 more that two new Kohler branded 24 584 36-S modules.Got some different coils today same part number but the ones that came today are a perfect fit. So if this does not fix it the spark module will be next
