Sammy the Red
- Sep 21, 2011
- 12
- 299
Do you have the 725K
I have the 727K.
I have the 727K.
I hope you good luck on the pigs. The first year I raised them I had very good luck with them, but not the second year. I had a lot of enjoyment doing it.. They would eat just about anything. They would get all my grass clippings and what was left over from my garden and every else's garden I knew. I also would go to a dairy farm and feed them their left over bad milk, they just loved it. Another place I found food for them I would ask a farmer after they would harvest a field of corn if I could pick the left overs which I did. The problem started the second year. The first problem was that I used the same pen over from the first year and we have a wet summer. The pen just turned into a mud pit and I just couldn't do anything for the poor animals. I tryed straw just to dry it up but nothing worked and i put some concrete in just so they could get out of the mud. The only dry place for the was inside the hut I made for them. The second problem I had was when the rats came. This was too much and the last of my pig raising. I only thing I hate more then snakes is rats. So when you make your pen make sure it is on good high dry drained land and try to keep all food cleaned up and sealed. Good luck
What I hope that all who are thinking of purchasing a zt have learned from this thread:
A major maker of zero turn mowers states,on their website, that the design is prone to turf damage unless a very deliberate turning process is used.
A very major maker of engines for the industry state, on their website, that the zero turn application is very hostile to the engine because, unlike the tractor (this is also mentioned by this giant of a manufacturer) which adds-by design- significant protection from abrasive/heat increasing debris.
A major maker of pricey zero turns, Grasshopper, responded to an email from me in which I inquired as to the towing capacity of their excellent mowers-the answer was damage to the drive was a concern if any owner towed a weight which was greater than what any owner -could move by hand (by the way the most 'vocal' advocate of this brand now admitts that using a JD lawn/garden tractor is FASTER on his average homeowner sized yard)
The lawn or garden tractor is by far, the best choice for ANY homeowner. The machine is safer, more comfortable, will do more, and will be longer lived than a similar quality zero turn-these statements cannot be intelligently refuted.
As to point of purchase remember this; only one maker-John Deere, offers a thirty day return on the purchase of a tractor, confirm that the product which you are interested in is included. As for the big box stores, the evil big box stores, they also offer a thirty day return period, or at least they do in my area, you perhaps should keep this in mind OR ask your local power equipment dealer if they will give you an extended demo or a purchase with return privledges.
Lastly remember that all of the most vocal defenders of the homeowner zero turn purchase have steadfastly refused to comment on what Scag and Briggs and Stratton post on their own website regarding info relative to this thread choosing instead to assign these thoughts to me.
In the end a zero turn will make zero sense-it did for me and it will for you.
Robert,
... definitely leaning towards the ZT. Every commercial mowing place seems to favor the ZT's, and obviously they want to get their job done ASAP. Time=money...especially to them.
I thought you did mine has the water cooled kubota it is much longer also have a 72" deck it is bigger both in length and width.
I also have the collection system and the metal box hangs out behind the rear wheels.
I knew your deck added a few inch's, but I did not know you had the collection box on the back. My nephew has that on his Z-turn. When I have used his mower, the box seems to get in the way when I make turns, can't swing around as easy as one without a box.
