- Nov 29, 2014
- Threads
- 64
- 24,705
You should be able to rotate the crankshaft now that you have got the top counterweight off the crank case.
Ideally you should always pull a single cylinder engine down at TDC on the firing stroke so neither of the valves are pressing on the cam.
Obviously you can not do this with a multi cylinder engine.
There are already marks on the gears & crankshaft so why not use them ?
Not really sure of your photo can you pull back on it a bit please ?
need to know which bit has the chunks out of it .
Also need to see the underside of the closure plate to see if there is a channel for the guide to run in and what condition it is in.
All of mine are the Mk II version.
Closure plates are expensive new but most repair only shops like mine will have a shed full of these engines because of the problem with the bolts coming loose & trashing the crankcase.
I have a heap waiting for me to try & weld back together but I can fit a Kawasaki engine cheaper to the customer with a 5 years warranty so it s a no brainer for them .
The eventual decision will of course be yours but we need to see the full extent of the damage first
Right now looks like a closure plate top counterweight & counter weight bolt , all very doable and not too expensive particularly if you can get some reasonable used parts .
