- Nov 29, 2014
- 24,995
If you swing it t the right as seen in the photo you should be able to rotate the crank.
You might need to do both at the same time .
You have the Mk I version which predates me by some time Just under the gear which turns the cams is the cam that moves the counterweight you will see that it is off set to the axis of the crankcase to give the to & fro motion.
Don't know what stops that version from moving left right
You will need to get your hands on a parts breakdown to see what is there .
The counterweight is in 2 parts held together with a long bolt.
Mine has a connecting rod that is bolted to the crankcase to keep it moving in the correct plane .
Yours has a "guide plate" but how that works is beyond me .
If some one does not chime in with better information drop a PM To Illengine, Rivets or Startech they have been at this game a lot longer than me .
Scrounges around the dead engine room but all of the dead Kohlers are the latter type like shown in my photos & the video .
