Kba9
- Mar 26, 2020
- 1
- 33
Yeah it's been take off. But there's still metal left from itIT should prize off but of course it is stuffed.
The bearing is not listed as being a repacement part.
SO you will need to take both the cleaned crank shaft ( bearing removed ) and the counter weight to a bearing shop.
There will be a replacement available but you might need to trim it to width.
Sort of glad you found that because it explains the out of position counterweight.
