MowerMike
I wonder how it compares to regular square line.
However if you are string edging the crossfire stuff just got used up way to fast
I used the crossfire that came with mine I honestly couldn't tell the difference. However if you are string edging the crossfire stuff just got used up way to fast
I just bought a regular blade edger, so I won't be string edging, but I do a lot of trimming along cement and brick walls. Also, I trim growth between gaps and seams in the driveway and sidewalk, so would the cross-fire wear down faster in those cases ? I saw a 3 lb (681') spool of Oregon .095 square line on Amazon for $27.94; is that a good deal ?
