MowerMike
Is the SRM-225 better quality than the PE-225 ?
Aside from the advantages of a straight shaft on the SRM-225 .vs. a curved shaft on the PE-225, I noticed a difference in the way the power head is attached to the shaft, even though the engines are the same, the housings are somewhat different. The PE-225 attaches to the shaft by pinching the plastic housing against the shaft, whereas the SRM-225 uses a cast metal semi-circular clamp with bolts on each side. The SRM is a more secure way of attachment and is less likely to crack than flexing the plastic housing on one side. Another interesting tidbit is that my SRM-225 was "assembled in USA", but my PE-225 was "assembled in PRC." A small detail for sure, but indicative of higher quality in the SRM-225 than the PE-225. Pricing on both units is about the same.
