Watch this link: and when done wait for the second link. If the 2nd link does not auto play after about 20 seconds wait time just clink on the link.
Keeps a heads up as to the valves opening closing and valve overlap. Very important that the valves be adjusted when the piston is on the COMPRESSION stroke and piston is going down 1/4 inch AFTER (past) TDC. (when adjusting per the service manual. If adjusting the valves on the ex stroke it won't run correctly or at all. About your ? about the timing mark being 180 out per your marks. Turn the flywheel one more turn and your marks will align and the piston will be at or close to TDC. The flywheel magnet (and your mark) goes by the magneto 2 times but only one is of the two revolutions is when the piston is at at TDC for the compression stroke.
This link will give you a refresher for a single cylinder 4 stroke engine.
https://www.bing.com/videos/rivervi...9A0C11A6A3A281A0B3B09A0C11A6A3A2&&FORM=VRDGAR
AND another that usually auto plays after the first one:
www.bing.com
How does a single cylinder 4 cycle engine operate? - Search Videos
Watch videos instantly on Bing—enjoy direct playback, discover related clips, and dive into trending content all in one place.
