Boobala
- Feb 15, 2015
- 200
- 7,000
Were you able to identify your block?
Wonder why he doesn't reply on that ??? ..:confused2:
Just an update. Swap is almost done. Everything is going great. All I had to do was swap pistons. Waiting for the gasket set to get here so that I can put the sump on the block.
Only concern I have is with the governor, external portion. I'm sure it needs some kind of adjustment, right? How do I know if the lever that clamps onto the lever that goes through the brass tube into the block is in the right position?
Thanks, guys! The gaskets come in tomorrow according to tracking. So I will get to that part tomorrow. Looking forward to firing it up! I'll take a video. Wish me luck!
Anything else I should be weary of or is it all down hill from here?
I didn't see anything about that mentioned in the above pdf manual provided above or on the youtube videos Ive been watching. Pretty sure kit only comes with one size gasket. .015 or something like that.End play.
Very important
Too little and the crank will chew out the bottom bearing section on the sump plate, too much and the flywheel will destroy the starter gears and perhaps even the magneto coils.
So bolt everything up tight with no gaskets , then measure the end float and select the appropriate number ( or single if you are lucky ) gaskets to take up the float.
Yes that is right, the end play is adjusted by increasing or removing the sump gaskets.
Do not put any sealant on them when you have worked out what the stack size should be.
I put a light coat of high temp axel grease on both the engine & sump so the gaskets do not stick & strip cleanly.
There should be 3 or 4 of them in the kit and usually each one is a different thickness.
