JonnyBlaze
- May 6, 2017
- 57
- 338
That's what I figured. I put throttle all the way up and backed off where I felt the notch for the choke.NO they mean throttle full open....
Right. That's what I did. I have the single lever. Model is LA125A according to the sticker on serial number tag. So what I said I did above is right, right?NO... when adjusting the cable IF you have a SINGLE lever for throttle AND choke...FULL fwd is the CHOKE position..
pulling back to the detent is FULL throttle .. when cold starting push the lever FULL fwd. to use choke,
when engine fires move throttle BACK past the detent to about half throttle. see OP instructions in link I THINK this is your mower model .... LA125 is the series, NOT the model, and look at the linkage when adjusting your cable.
ok. I understand now. I didn't think lever was supposed to be all the way forward, choke engaged. I'll do it tomorrow morning. Thanks. Sorry for being a pita.YOU said you moved it BACK from full fwd to the detent, WRONG !!!! lever full fwd. loosen screw, locking the cable OUTER jacket, push white piece ( if that's what YOU have, ) fwd to where the CHOKE linkage is moved FULL fwd. ( CHOKE in closed position, ) lever still in full fwd. pos., .. keep white piece in position and tighten locking screw, now throttle lever should move from CHOKE position, to detent ( WOT ) then idle position, FULL back
(or ALMOST full back) Pics of your linkage would be helpful, or maybe another member can explain it better than I can.
Do I have to adjust the governor again after?RE-post if we need to go over it........ Boo
