Today, most conventional oils are blends. This is done to meet current requirements for fuel economy and engine manufacturers.my current van has 1,682,000 km on it and has seen nothing but whatever 20w50 I can buy in a 44 gallon drum .
True synthetic oil is made from gas then the molecules are broken up and reassmbled to make a liquid which is very expensive
Traditional oils are distilled & filtered off the crude oil as a liquid .
Semi synthetics are made by breaking down traditional oils into all of the component parts then reassembling it using only the bits you need.
This is standard proceedure for thousands of items that need to be exactly the same day in & day out like sugar, bread makers flour, carbon black .
and why people call traditional oil dino oil I have no idea as it is the remains of vegetable matter not dinosaurs and most of it predates dinosaurs
Yes they are blendsToday, most conventional oils are blends. This is done to meet current requirements for fuel economy and engine manufacturers.
Do your google research, Wix oil filters are extremely effective filters, Frams, Stp etc... not! Check a few sites that have tested most filters. You could be surprised! OE filters also top pick, usually.Hello everyone, I have a Husqvarna LGT2654 with a Kohler KT745. I need to change the oil there is currently a Wix 51056 oil filter on it. I want to put a Kohler but can’t find it. The sticker on the machine says part number 25 050 40 which is like hunting a ghost. I’ve researched and come up with 2 possibilities. Kohler 52 050 02-S which I bought but haven’t unboxed because now I see a Kohler 12 050 01-s is recommended.
Can someone please educate me. Will they both work? Or which one is it?
If it fits will it work?View attachment 64620
I really appreciate any information shared. Please help!
