metz12
What you need to do is sit the mower level and weld the axle to the sleeve that it sits in or drill two holes one on each side of the center hole and put bolts threw.
I have a solid cast axle off a poulan so I welded plates on the top and bottom of the sleeve.
Because it is a pain in the azz to weld thin steel to cast.
Sent from my iPhone using LMF
oh ok. i see what you did there. and, did you get those videos up? what is your youtube name?
