On my sixth season with the MZ now. I realized two things getting on this forum tonight...1) I forgot to post anything at all last season...sorry :ashamed:; 2) photobucketheads strike again
I moved all my pics to another host, but I don't know if I can edit all the above posts to re-insert the blocked pics.
Back to my annual report.....last year was another wet year, so there was lots of bagging. I honestly don't know what I would have done in these high rainfall years with the old Dixon ZTR. Somehow I got away without a bagger on that mower for 13 years. Anyway, lots more clippings last year added to the compost mountain. No problems with flooding, nor mystery temporary dead switch episodes. On the fuel issue I've simply gotten into the same habit I apply to my old gravity feed Ford tractors...shut the fuel off whenever I get through using it.
So far this year I've only mowed once. We've had an unusually cool March & April, so things have been slow to start growing(not complaining). I guess I haven't been as diligent as I thought keeping track of blade wear, or, this set of blades went south REALLY quick. I had picked up a new set last fall to install end of season, but didn't get around to it until I pulled the mower out of mothballs last month.
The wear was so severe on a couple of them it could have been a projectile flying who knows where. I've never seen a set worn to that point before...will definitely be keeping a closer eye on the new set. Other than that scary event, the MZ is running & operating really well. Basic maintenance & keeping relatively clean seems to be all it wants. Oh yes, forgot one thing, the deck drive belt gave it up last season. My fault....I didn't realize the belt jumped off the drive pulley & the idler had enough spring tension to keep turning those blades, so I didn't figure out the problem before the belt frayed. Didn't last long after that.
After 5 years of use my only complaint with the MZ is the job of cleaning the underside of the deck, just no easy way to do it. Everything else has been a great experience. I still look forward to climbing on it every time, almost as much as my old tractors.
