.....this makes me question the mz 5225 since the bagger for it needs the assist motor for the catcher $$$.... Ill have to go research what that bagger you got cost.....
The bagging kit I ordered was $549 w/ "free shipping" from Mowers Direct, but I noticed the suggested retail on the Husky site is $499. Not sure what a dealer would sell it for. That is interesting the 5225 needs the assist motor version of the bagger(which is double the price). I don't know what's different about the the two mowers other than engine brand. Just FYI, I rec'd some bad feedback on the power assist bagger when I was researching & shopping. Nothing about performance, but that it was a pain to install & remove.
Im not 100% sure the MZ5225 takes the blower assist vac collection system but I think it does because that mower (MZ5225) has a fabricated deck.....
I went back & looked at the website, you're right, the blower kit is the only bagger that fits the 5225 deck. I guess the heavier deck & blower are more of a commercial touch. I don't think I would try my bagger w/ heavy dew or other wet conditions.
Good luck on monday.
Congrats on the mower Jeff!
After searching waaay too much, I think I'm getting the same machine with a bagger. I was debating between this and the kubota and Hustler, but I think Husky is what I'm doing.
Jake, I think you will be very pleased with the performance. The bagger has been a real time- & trouble-saver this spring....I can't remember a year we've had such heavy growth week after week. The bagger for the 5224 holds 9 bushels of clippings & I'm averaging 25-30 bushels at each mowing so far. That should slow way down now that the we're going into our typical Texas dry hot summer.
Great to hear Jeff.
Are you happy with the cut as well?
......The real test will be later in the summer when some of the foreign grass gets really dry & tough.
Not sure if any mower will pass that test :laughing:
.......After searching waaay too much, I think I'm getting the same machine with a bagger. I was debating between this and the kubota and Hustler, but I think Husky is what I'm doing.
Jake....did you end up getting the Husky or the one of the others? How did it perform?
Jeff
3rd season for the 5424 just started for me. Very late start because of so much rain. The ground has been so spongy I could hardly get off the pavement until the last couple of weeks. Other issues conspired to delay my 1st mow of the season until this past weekend.
Just like last year I "Texas winterized".....treated fuel, shut off the fuel valve, burned the remaining fuel in the line & carb, oil & filter change, etc., used a float charger on the battery. The result was no problems with start-up.
With so much rain & quite a bit of warm weather since early March you can imagine the yard looked more like the pastures than a lawn. It was mostly weeds because I didn't get out any weed-n-feed on it. Most of it was 8" to a foot high, but not thick like turf. I set the deck at maximum height & installed the bagger. With that set-up I generally went over everything around the house twice to get a clean-looking cut. To my surprise I had no clogging issues, & the clippings were plenty damp. That night it rained again & I still had the outlying areas to mow.
Next day was windy & sunny, so I let it do it's work & waited to end of the day to start mowing again. More rain was forecast, so I was determined to get everything cut. What a mess....not so much with the bagger, it actually handled things pretty well. My deck couldn't keep itself clear for very long.....the sludge would build-up & the deck couldn't move the clippings across to the chute. The center & right side blades sent their clippings up the chute, but the left blade was essentially mulching after the 1st 10 minutes. I stopped & cleared the deck several times & got through it, but I have to admit I was wishing I had one of those tilt-deck machines to make cleaning a bit easier!
Obviously not a good idea to mow in those conditions, so hopefully I won't be in that situation again this year. We'll see. :ashamed:
My last post was 5 or 6 weeks ago, & the engine was having what appeared to be flooding issues, but never found a definitive reason why. All I can tell you is it cleared up as quickly as it started. Last thing I did was change the oil & filter. One thing I noticed was the oil was very thin when I drained it(which had 50 hrs on it).
After all the bagging last spring & early summer it turned out to be a dry mid & late summer around here.
Jeff
On my sixth season with the MZ now. I realized two things getting on this forum tonight...1) I forgot to post anything at all last season...sorry :ashamed:; 2) photobucketheads strike againI moved all my pics to another host, but I don't know if I can edit all the above posts to re-insert the blocked pics.
Back to my annual report.....last year was another wet year, so there was lots of bagging. I honestly don't know what I would have done in these high rainfall years with the old Dixon ZTR. Somehow I got away without a bagger on that mower for 13 years. Anyway, lots more clippings last year added to the compost mountain. No problems with flooding, nor mystery temporary dead switch episodes. On the fuel issue I've simply gotten into the same habit I apply to my old gravity feed Ford tractors...shut the fuel off whenever I get through using it.
So far this year I've only mowed once. We've had an unusually cool March & April, so things have been slow to start growing(not complaining). I guess I haven't been as diligent as I thought keeping track of blade wear, or, this set of blades went south REALLY quick. I had picked up a new set last fall to install end of season, but didn't get around to it until I pulled the mower out of mothballs last month.
The wear was so severe on a couple of them it could have been a projectile flying who knows where. I've never seen a set worn to that point before...will definitely be keeping a closer eye on the new set. Other than that scary event, the MZ is running & operating really well. Basic maintenance & keeping relatively clean seems to be all it wants. Oh yes, forgot one thing, the deck drive belt gave it up last season. My fault....I didn't realize the belt jumped off the drive pulley & the idler had enough spring tension to keep turning those blades, so I didn't figure out the problem before the belt frayed. Didn't last long after that.
After 5 years of use my only complaint with the MZ is the job of cleaning the underside of the deck, just no easy way to do it. Everything else has been a great experience. I still look forward to climbing on it every time, almost as much as my old tractors.
