3rd season for the 5424 just started for me. Very late start because of so much rain. The ground has been so spongy I could hardly get off the pavement until the last couple of weeks. Other issues conspired to delay my 1st mow of the season until this past weekend.
Just like last year I "Texas winterized".....treated fuel, shut off the fuel valve, burned the remaining fuel in the line & carb, oil & filter change, etc., used a float charger on the battery. The result was no problems with start-up.
With so much rain & quite a bit of warm weather since early March you can imagine the yard looked more like the pastures than a lawn. It was mostly weeds because I didn't get out any weed-n-feed on it. Most of it was 8" to a foot high, but not thick like turf. I set the deck at maximum height & installed the bagger. With that set-up I generally went over everything around the house twice to get a clean-looking cut. To my surprise I had no clogging issues, & the clippings were plenty damp. That night it rained again & I still had the outlying areas to mow.
Next day was windy & sunny, so I let it do it's work & waited to end of the day to start mowing again. More rain was forecast, so I was determined to get everything cut. What a mess....not so much with the bagger, it actually handled things pretty well. My deck couldn't keep itself clear for very long.....the sludge would build-up & the deck couldn't move the clippings across to the chute. The center & right side blades sent their clippings up the chute, but the left blade was essentially mulching after the 1st 10 minutes. I stopped & cleared the deck several times & got through it, but I have to admit I was wishing I had one of those tilt-deck machines to make cleaning a bit easier!
Obviously not a good idea to mow in those conditions, so hopefully I won't be in that situation again this year. We'll see. :ashamed:
