Hammermechanicman
- Jan 10, 2020
- Threads
- 56
- 3,543
Going to assume you have the D1005 engine. When you turn on the key does the glow plug light come on for about 10 seconds then go off? If you sprayed diesel into the air intake with hot glow plugs you should get some kind of fire out of the engine. Hot glow plugs+compression+fuel should at least give you something. Do you get any kind of black or white smoke out of the exhaust?
When you say loosened the injectors are you loosening the line at the top of the injectors or loosening the injectors themselves? you need to bleed the system up to the injector pump before bleeding the injector lines. Don't loosen the injectors themselves. Is there any fuel up to either filter? Do we know if the lift pump is working?
