Experts say an engine needs to see 200F + temp to drive out moisture /condensation. At 40F here and running about 20 minutes with light hauling the Intek would not rise past 168F. Idling will not change that. I guess this says repeated running like this is not good and relies entirely on oil additives to deal with trapped moisture which would seem to finally reach their limit , allowing corrosion and sludging to begin.This temp being read on a Depo electronic gauge. (Never happy , right? Usually too hot. Where are the 3 bears?)
