He has the deck setup like that because it gives the best cut and stripes the grass better. But does work the engine harder.
It is called heeling the deck. I run all my mowers with the front up higher than the back been doing this for 30 years.
Thanks for the info ....
so you raise the front of the blade 1" or more to get the stripes as you see on a baseball field?
good to know....
