 - Nov 29, 2014
- Threads
 - 65
 - 24,995
Before I go back & correct some of the gross inaccuracies in the previous posts presented by people who have not read the entire thread before posting their pet fixes for everything, some of which are good , just not applicable to your dilemma .The magnets did stick to the spindle housing...
Considering the cost of replacements it is worth while to take them to a real mower repair workshop or mechanical workshop where they have both the equipment & knowledge to dissasemble your 3 spindles as it is off season you have a bit of time up your sleeve .
Note I said real mower workshop, the type that has a small shop front with a lot of used mowers for sale not the big multifranchise glass fronts who only sell used mowers .
Be upfront, tell them you can not get the ends off and that is all you want them to do if you intend rebuilding them yourself.
If you get them to rebuild them check that they put some anti seize on that thread .
FWIW the housings that Swisher use and the ones on the Ariens Zoom are almost the same as yours and I had to resort to the 1" drive rattle gun and special tools made from cut down impact sockets to get that bottom housing off , although in both cases they were well beyond the "noisy" state.
