Bert thanks so much for all your additional thoughts. Here's my run down on those...
Spring 1 - 10mm Compression = 12.5Kgs - 20mm Compression = 23Kgs
Spring 2 - 10mm Compression = 12.5Kgs - 20mm Compression = 22.6Kgs
Spring 3 - 10mm Compression = 12.7Kgs - 20mm Compression = 22.5Kgs
Spring 4 - 10mm Compression = 12.3Kgs - 20mm Compression = 22.9Kgs
I should minus the weight of the 2 block I used on the scales (maybe 1 Kgs) but the resultant is the same.
Height were all within 1mm of each other and max compression was 22mm for all 4 springs
This kinda the Faultless Engine with Problem! :laughing: ... But please don't give up on me guys ... someone is gonna crack this for sure :thumbsup:
We've hit Page Seven ... and Seven's my lucky number
Yes but in hindsight the test really didn't compensate for human (me!) error and the minute differences between the adjustments on each rocker. I don't believe we can beat a high accuracy (digital vernier calipers) measurement directly on the cam lobes and the relative positions of the peaks of each lobe. The order of individual cams positioned on the shaft are Exhaust 1, Exhaust 2 then Inlet 1, Inlet 2. So I've just measured the straight line distance between the peaks Exhaust 1 to Exhaust 2 as 14mm and Peaks Inlet 1 to Inlet 2 as 14mm.... I also checked each cam for play on the shaft and the main gear play on the shaft ...there's no play on either. If you could see the cam you'd see it's in excellent condition .... Remember the fault has been there for quite a few months now so if the cams lobes are rotating on the shaft the damage/wear would be easy to see by now.I will still go with a cam defect.
The figures quoted with the tape test definitely show one cylinder lagging behind the other.
As the cams are pressed onto the shaft on a spline I am guessing , and this is a wild guess yours are out of time.
My closest B&S stockist (that would stock a cam) is 50 miles away and they are really an online store and not so helpful.If the local B & S dealer is a nice guy take your cam and ask him to compare it to a new one.
Checked the rods once again. The two Ali ones are identical in length and the two Steel ones are identical in length. Both Ali ones are 0.5mm longer than both Steel ones. I rolled them all on a sheet of glass checked the ends and they are all in excellent condition.Check all of the pushrods for length & straitness.
Also check that the alloy ones do not have a worn ring & are hanging on the shoulder of the worn area.
Also double check the valve spring length and spring rate.
This was a great test and here's the results from my Digital Bathroom Scales in my Drill Press ....Also double check the valve spring length and spring rate.
Cheap & nasty way is to put a bathroom scale on the deck of a bench drill ( a press is better ) then compress till the spring is 10mm shorter.
Read the "weight" shown on the scales. They all should be within 10% of each other or better.
