Carscw
 - Aug 11, 2011
- Threads
 - 66
 - 6,375
Actually the comment was sarcasm but as always right over your head. Actually Daydream came out in 1966 it was there second album under the Budda Records label. What a day for a daydream came out in 2003 on the album Summer Vibes.
Yes I got the sarcasm
Not sure what your problem is with me but no matter what I say about anything you feel the need to run your mouth.
Like I have said before just because your dumb and can not do something does not mean it can not be done.
You like to brag on here about the equipment you keep buying but I think your full of crap thinking you don't even cut your own yard never mind do it for a living.
When I leave here you will find someone else to start your immature crap with. Before me it was jmurrary - twall - jd green
Between you and your teenage clone your on here so much I don't see how you have time to cut grass. Your good at running your mouth and doing the copy and paste thing. But man you don't even change your own oil.
I try hard not to post on anything you have but you flipping stock me.
And the way you say you do lawn care. Ha ha your just a mow and blow hack
This is my last post as I won't be harassed by you.
Sent from my iPhone using LMF
