This is from July 18th, 8:30 a.m. so it starts right up and it still goes into the hunting and surging. Maybe there is a vacuum leak. I've ordered two new head gaskets. The good thing is I don't see any oil around the chassis area. I was concerned about oil coming out of the engine. The hunting and searching might be reduced with a new head gasket or even sanding down the cylinder head. I've considered a shop to machine the whole cylinder head and the only part that I still am concerned with is the temperature is about 750° f. The engine is just sitting there. There is nothing going on. Matter of fact it's trying to idle but that temperature I think is pretty high for the machine. Pretty much doing nothing. I wish they could run about 400°. F but this video represents the best. It's been in maybe 7 weeks and again I am not a small engine mechanic. I'm just doing the best I can to figure out how to get it back to where it was with a lot of good information from various individuals.
Jim
Next step is to put a industrial fan blowing on the engine because I don't have the cooling installed and see how much that drops the temperature.
