But putting aside the current current problem entirely and I'm going back to 3 or 4 years ago. When I got this machine the owner overfilled it with oil and how did that happen? And my conclusion 3 or 4 years ago was there's something wrong with a specification sheet or somehow when you drain oil out and take the oil filter off and do all that stuff. There's some residual oil and I don't know how much that quantity is but I think what he did and this is very important. Is he drain the oil out of the engine? He took off the oil filter and he said to himself there's no more oil and then he went by the spec sheet and whatever it is for sake of argument say it's 48 fluid oz. I don't know right now and I'm not going to look it up but he went by that spec sheet right from the get-go. He had way too much oil and that's where his problem began. So what I did back then was I never went by a specs sheet. I put oil in slowly like maybe every 6 oz I put in and I kept checking the dipstick and that's what I did say 6 weeks ago and I thought the oil level was correct because at times it's tough to read what's going on with the oil but that's the way I proceed it and I'm guessing I underfilled it because I was so afraid of overfilling it.Toby, thanks for the input and now that I'm totally more awake, you know I agree with what you're saying. Something goes wrong with the engine. Consider that one variable and then you still have that one variable. But now you introduce another variable some other carburetor. Now you got two variables. You had one but then you now have two and I'm very familiar with that. I will clean the carburetor but you don't really know the history of this. So 6 weeks ago everything was running great until the engine just stopped and it could have been lack of oil. And during that same event the exhaust pipe got so hot that the muffler separated from it in a couple days prior to that. What prompted me to do anything repair wise was there was a lot of smoke and it was either coming out of of the head gasket area or the valve cover gasket area. And I also did drain the oil maybe 2 months ago or maybe it was right around the same time as when all these issues all came about you don't know that because you read what I write. In any case, I'm going out in a couple hours and see if this thing runs but the only takeaway I can give you the more I think about all this there was no carburetor issue. It was really running very well. Say a couple months ago there was nothing going on except smoking and then from there I could have potentially made the whole thing worse because I didn't exactly know how to fix the smoking issue but the carburetor was not what caused every the engine is shut down while cutting. It was instant and the carburetor was perfect. But who knows, there's not. I'm not arguing with you about this. It's just a good idea to clean it and keep it the way it was. I just want you to know it probably wasn't the event that caused everything to go wrong, maybe 6 weeks ago.
Jim
