Hammermechanicman
- Jan 10, 2020
- Threads
- 69
- 3,905
Ding ding ding. We have a winner.. Besides all my vendors demand payment up front for the parts.
Yelp that the way I had to go too as they will otherwise just make a partial payment just to get their equipment and then stick you for the rest.When a customer asks if they can make payments I'll tell them "Yes, I take payments. And when the payments are all paid, you can have your equipment."
Yelp those wish lists to get long sometimes. Just keep your growth at a manageable level. That why I don't advertise here.
As for the compressor I have been running a 25 gallon one for years. Several years ago it was looking like I needed a bigger set then I switch over to Air Cat tools that are more powerful but used less CFM with them being quieter too. Now air guns still take a lot CFM but just the nature of them. One of things you can do is too switch from those M or L couplers to high flow V style coupler and plugs. Those M's were my best problem with air flow problems. I recommend V over other hi flow because if you need to use a tool that still has M style it is possible as the V couplers are dual use though the M's adapters will leaks are the V o-rings wear.
As for tools I start out the basic hand tools and add as I needed things. Currently my work bench is three 4x4 across the 17 cu ft utility trailer with 1x6 tongue and groove planks nailed to them. Yes I do most of my work outdoors. No way to work in the shop as it is only 24 x 24 building that is full parts and tools. I started out with one 26" tool box and now got two sets 44" top and bottom boxes along a set of 26" top and bottom boxes. Even now I am needing to add tool boxes.
Parts is your second biggest expensive behind tools. Just keep it at a manageable level too; otherwords, don't go hog wild buying parts. Yes if you got a particular part you use a lot then yes extra of it. When I first I did buy several starters and even after 10 years I still got most of them but the rest of the current stock usually is rotated out within a year. Just don't items for older equipment as they die off leaving you stuck with the parts; unless, sell them on eBay as NOS parts.
