The Brain
- Jun 26, 2019
- 77
OK the cheap cam most likely from china is outtof consideration.I do agree with Scrub and Bert, not your best bet buying cheap aftermarket parts. Just didn’t know how low you were thinking when you balked at Jack’s prices. Have found the OEM part available at HomeDepot for $67.00.
now I have the correct part # I will search, I assumme this HD part is still available a link would be a big $ saver. thanks Guys I'll be degreasing the snapper prepping engine removal.
edit: I ordered a starter for the snapper this.https://www.walmart.com/ip/DB-Electrical-SBS0004-Starter-For-Briggs-Stratton-11-To-25-Hp-Engines-497401-494198-494990-112563-BS-399169-BS-499521-75255-75255-A-410-22005-410-220/195508814
wasn't installed because I found out the starter requires a plastic gear. I'll need advice on the starter also
I think this could be the correct starter not sure if it's OK to post a link https://www.partswarehouse.com/Briggs-Stratton-Motor-Starter-BS-593934-p/bs-593934.htm
dam why is the correct starter 3 times the cost of simiair starters?
thanks Guys for support TB
