worn out cam preventing ignition, cam swap or engine swap
  • / worn out cam preventing ignition, cam swap or engine swap
You definitely are missing a digit. Take a pencil and rub it over the code number on the original engine, the missing number will magically appear.
The Brain
# on valve cover
new to me engine
Model type code
219907 0131 B1 0805212A
Orginal engine
219907 0131BL 0864307A
The Brain
the orginal engines bottom end is fine.
can I replace the compression cam & cylinder head w/ improved valve train and keep as a spare engine.
replacment engine is strong second mow in week or less. then I'll know if I have a decent engine. I'm thinking of using amsoil 30weight oil. what do you guys use?
