StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,484 Location Pluto May 5, 2020 #11 I believe you are referring the to screw in the adjuster. Briggs only sell it in a kit. Briggs PN 691986 ADJUSTER, Rocker Arm
Roddersq Forum Newbie Joined May 4, 2020 Messages 4 May 5, 2020 #12 StarTech said: I believe you are referring the to screw in the adjuster. Briggs only sell it in a kit. Briggs PN 691986 ADJUSTER, Rocker Arm View attachment 52063 Click to expand... Yea that looks like the part ok Thanks a million
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Messages 24,995 May 5, 2020 #13 Nothing special about it, it is just a grub screw with a torqz hole in place of a std hex hole . Just remember you adjust with the nut and lock with the screw which is the opposite to all other engines .
