Valve lash tolerance on 15.5 Briggs intek engine
designr
I was wondering if anyone knows the proper valve lash on a 15.5 briggs? I saw somewhere that the intake was a thousand or two larger than exhaust and i saw that both were set at .004 any input would be great. also it said set them a 1/4" past dead center past top. thanks
EngineMan
Will tell you if you post up the engine numbers, or better still.....!
  • Check Chart common_specs_english_all BRIGGS & STRATTON_engines.pdf
designr
Thank you very much I copied the chart it is really great and got everything set
Roddersq
Hi guys I'm having the same problem with my mower I'm trying to set the valves now but looking at the chart above doesn't correspond with any model numbers on mine
Its 15.5 hp ohv only model number I can see is on the valve cover 282H07
Intake .003”-.005”. Exhaust.005”-.007”
Roddersq
Think I have it sorted but unfortunately I have rung the center torque lock nut
Any idea where I'd get one
Checked briggs parts but cant find it
Maddening
Would need the type off the valve cover. 282H07-????.
