Valve lash tolerance on 15.5 Briggs intek engine
I believe you are referring the to screw in the adjuster. Briggs only sell it in a kit.
Briggs PN 691986 ADJUSTER, Rocker Arm
Nothing special about it, it is just a grub screw with a torqz hole in place of a std hex hole .
Just remember you adjust with the nut and lock with the screw which is the opposite to all other engines .
