Yes I get Sundays off from regular work. It is one thing my boss insists on. Besides no one like paying my Sunday rates which is not as bad as our 2am rates.You mean you actually get Sunday off. I spend this morning taking care of a local farmerswhose seed tender wouldn't start and they can't load their planter without. it. Symptom was they had ran it out of gas, refilled it, and then it wouldn't restart. They got is running temporarily but then died and wouldn't restart. Replaced the flooded plug, and then had no spark. Found that the issue is with the wiring on the Meridian seed tender. Will not start with the key switch but did get it were it would start with the remote control.
One Briggs price file set modified and now need the three files merged before importing. This way all the supersedes are properly applied. Also got the formatting under CSV format especially checking for stray commas in description field.
Nor do I. That is why I use tachometer to set these idle speeds. There is no way I can tell the difference between 100 change.Thanks for the reply. I bought the mower new and for 2 1/2 years the mower performed flawlessly. Started very easy and run like a top at slower throttle as well as full throttle. Always when the blades were engaged the throttle was full and never had the surging sound. It only has the surging sound only after they messed with the rpm’s and the surging is only noticeable at full throttle when the blades are engaged and not when it is full throttle with them not engaged. I am not a mechanic and never has been but thought it odd that now this is happening. You posted that idle speed should be 1450, now I don’t know what that should sound like but after they adjusted the rpm’s the idle seems really higher pitch and fast so didn’t know if there was a correlation between the 2 or not.
Now the posted idle speeds are set independently of each other but they do interact with each too.
While the engine is running.
- First the carburetor idle speed is set while holding the throttle plate closed.
- Then govern idle speed is set.
- And finally the high idle speed (off load full throttle speed) is set.
If the tech set this up properly and the engine is still surging then there is a problem with the carburetor most likely; like it needs at least a good cleaning. Usually when under load surging is caused by a dirty carburetor or valves out adjustment or both.
And as a shop I can't assume anything as I don't who all has fooled with the equipment that comes in into my shop. I just had an Exmark that came that several other techs had mess with the engine trying to get the surging out. They had both carb idle and govern idle speeds the same plus also had removed the fuel filter and inverted it on reinstall sending a lot trash into the carburetor. It took me 4x cleaning it to get all the grass out of the carburetor.
Also Kawasaki engines are know to smoke at start up if anything other than 15W50 or 20W50 oil is use. This is why Kawasaki sells a SAE15W50 synthetic oil.
