Carscw
- Aug 11, 2011
- 66
- 6,375
Ok let's start off easy the tie rod runs from wheel to wheel on the back side of the front tires On each end it will drop into a hole on the underside of the hole will be a clip or cotter pin type thing pull them out then remove rod. Next step take a tape or a yard stick set front tires so they are the same distance apart on the front side and back side so they both aim straight forward now measure the distance from the two holes you took the rod out of should be close to 19 1/2
Now take the bend out of the rod until you get what you need. And YES in the middle of the rod it comes with a little bend I will post a pic for you tomorrow Let me know when you get this done and we will make a home made rod for the deck
Sent from my iPhone using LMF
