I recently changed oil and filter on a zero turn with a 18hp Briggs & Stratton. I used 10w30.
Since then when I go down a steep hill it will blow a ton of white smoke, stutter, and sometimes die.
I thought I had overfilled the oil so I drained it until it was in the lower range of “safe”. No change.
Any ideas?
Any ideas?
