primerbulb120
- Nov 3, 2014
- 43
- 1,315
Re: MTD Yardman Transaxle Rebuild
There are 3 parts to the air cleaner on those engines. The cover, the filter, and the base (this is the part that bolts to the carburetor.) Removing the cover and filter won't cause any problems. However, if you remove the base, you'll tear the gasket behind it, which will prevent the engine from priming. You can replace the gasket, but even then you have no guarantee that the engine will prime. The bases on those engines are plastic, and they like to warp because of heat created by the engine. When you remove them, you break the seal created by the original gasket, and the warped base won't seal correctly with the new one. Sometimes you can fix the issue by installing 2 gaskets instead of one, but if the base is warped badly enough you'll have to replace it.
Clyde
You better DON'T pick on this ol-fart that's havin brain-farts,
NO MATTER ... it WAS a Murray with THAT style of Briggs.
Clyde
