Roger B
- Oct 19, 2016
- 11
- 1,656
Re: Compressor repower
Chuck-san,
That is not always true, because appliance manufacturers fall under a different section of the Code altogether... Sort of like the power company. Check out the size wire running across the street from the transformer feeding 4/0 cable for a 200-amp service on a building.. It's always like #2 or something.. The same applies inside a machine. I've never had to follow the rules they do, so I can't explain it, but I know they have different requirements. usually less stringent.
Rog
Just so you know. The feed wire never needs to be bigger than the largest wire in the motor.
Chuck-san,
Rog
