wjjones
- May 29, 2011
- 50
- 1,456
possum,
I resemble that remark(guys 60 and up:0)......but kinda like you, I mostly use the Stabil(but I also run "non-ethanol" gas in my boat and all lawn equipment). I put Seafoam, though, in my boat at the end of last Summer because I filled it up at the beginning of Spring last year and only ran about a quarter tank out of it. Since the Seafoam(IMHO) is a "heavier duty" treatment than the Stabil, I decided to use if for winter storage in the boat. Also, I've read many testimonials that if you have any type of small engine that is reluctant to start up because it has been "compromised" by running ethanol gas in it that the Seafoam will definitely get it going again. Seafoam also got my 1995 Chevy truck to pass emission testing one year after it failed the first test. After that, I started putting a fuel system treatment in the truck each year and it hasn't failed since. That Seafoam is indeed good stuff!!!
Yep it helps keep the varnish out from stale fuel.
