I do have a replacement discharge chute on order since I cut mine. I may go back to using the unmodified one again, and probably need to restore it anyway if I trade the machine in.
Since I already cut the old one, I wanted to experiment creating an "operator controlled discharge chute" - a blockoff plate to prevent discharging in to my flower beds. I have a fairly narrow swatch (about 8 feet) between my two primary planting beds that gets filled with grass. I just mulched it two weeks ago with some dark brown mulch and it looks gray already from the yellowed grass clippings that have blown in when I mulched.
Works OK, not great. I have to manually flip it down when I'm passing through the flower bed area, and then I manually lift it when I'm done. Although it's a fairly heavy steel plate, it does lift from the discharge and will still blow out some clippings. I'm thinking of drilling some holes in it to allow the air out, but keep the grass in.
