Correct that's why Hustler came out with a modification kit to fix the discharge problems. I did it to mine and it is a big improvement!
Here is the kit;
Here is how I cut the cut the deck opening bigger;
Here is the kit installed on my SD54;
Kit part # 123352
Attached is the factory bulletin #603 explaining how to do the mod.
Here is the kit;
Kit part # 123352
