The G5 Gatotor blade should improve the cut quality of the mower, the only down fall to using the blade is that you could possibly loose some blade tip speed because they are a little heavier. The thing I like is the extended cutting length, I think that itself can make a big difference. I use the G6 blades on my mowers.
I don't see how any loss of speed could happen unless something is slipping. Governed RPM is the same regardless of blades and nothing is slowing down unless the engine is already at wide open throttle and doesn't have enough torque to keep up.
I think the extended edge is most of why the clippings are smaller, more chance to get re-cut before making it out the side.
