Push Mowers on Lawn Care Trailer
fatboy
I use bungees and have in the past nailed a 2 by 4 behind the rear wheels to hold them in place
Carscw
The 2x4s work good I put one in front of the front tires and one behind the rear tires.
Yeah that would be cheaper, but I don't know if I would rather drill holes in the floor for the wood pieces, or holes in the metal side for the wheel boot.
exotion
If you drill holes in your trailer metal you will expose metal and it can start to rust
Carscw
That's true and in 30 years you will be sorry you drilled them holes.
You could just paint the holes.
Ric
Ric
Unless you have some good metal drill bits, drilling holes in the floor would be the way to go depending on the thickness of your plywood. It's not like your trying to restrain q 700lb mower.
How about just a bungee...
Thats what I use is the thick black rubber bungee cords from TSC it makes it alot quicker. This is a good thread though because I am always looking for a better way of securing equipment for transport.
Carscw
I use bungee cords a lot but I stay away from the black ones because the sun in the summer they break. Maybe I pull them to tight?
