I will be the first to agree that the Cub GT2000 falls between the LT-GT classification as, from the factory, true garden tractor implements cannot be had-I think the best way to describe the Cub 2000 is to look at this machine as a -crossover- garden tractor.
What the owner of a Cub 2000 series gets is an exceptionally well built tractor, an exceptionally well built large tractor, with a fantastic Kohler Command horizontal engine with a very large air filter, shaft drive to a true garden tractor drive-BU10, external spin on filter, just about 6 qts of juice, bolted on very large rear wheels/tires, cast iron front axle,fast forward/reverse speeds and the choice of fab or stamped mower decks PLUS the ability to tow just about a ton-and the owner of a Cub 2000 gets all this-(a very heavy duty crossover tractor, that mows better than the Exmark zt I had, that is quieter than the Exmark zt I had, that is far more comfortable than the Exmark zt I had, that has a much higher end engine than the Exmark zt I had, a much higher end drive than the Exmark zt I had) for significantly less cash than any higher than entry level zt which will have a consumer grade engine, drive and capabilities with virutally no towing capacity.
Think of the Cub 2000 as a thinking persons X500... which comes with a much more heavy duty drive but without a locking diff/traction control :smile:
For those who have not looked at the many pictures that show just how well the Cub 2000 is put together take a look for yourself;
betsy-tom (betsy-tom)'s Photos | SmugMug
scroll past all the text and look for the Cub Cadet galley.
By the way, my friend tells me that the Cub section is still receiving about 50 hits per day.
