I've used them all over the years....from a flimsy 20" push mower to a 26" Yazoo beast that my dad used to mow yards in the 50's when he was a kid, to lawn and garden tractors, to ZTR's and full size tractors. Come to think of it, I've even had the "pleasure" of using a "real" push mower and even a greens mower. Each has their place where their strengths and weaknesses shine through.
As mentioned above, the lawn tractor is the cheapest and lightest of the riders....well with the exception of some of the RER's. It is well suited for the majority of yards where the size is under an acre to maybe an acre and a half, is fairly flat and mostly smooth. They can pull small utility carts around the yard for various tasks. They are fairly manueverable, with some having a very small turn radius, but you'll still need a trimmer or some Round Up. However, they won't last long if you try to bush hog with them or use any type of ground engaging equipment.
The garden tractors, as also mentioned above, are heavier and more costly than lawn tractors. They are well suited for larger yards, or those with heavy terrain and not exactly golf course smooth. They can also pull larger carts/trailers around the yard, use ground engaging equipment, and some of the larger ones can even come with hydraulics and three point hitches and front end loaders. They aren't quite as manueverable as a lawn tractor, but some are available with four wheel steer making for a very tight turn radius. However, you'll still need a trimmer. Since they are heavier, they tend to tear up a soft yard that a lawn tractor wouldn't.
The ZTR's are, in IMO, the best option if all you have to do is cut grass, and a lot of it. They come in a wide variety ranging from light and cheap to heavy and very expensive. They will almost do away with any trimming needs, and in most cases, will seemingly run circles around any tractor style mower. Some will disagree, but generally, ZTR's are not well suited for moderate to steep inclines or rough terrain. They typically have very limited utility for any work beyond mowing.
I personally prefer tractor style mowers. They offer a better ride and you get more mower for your dollar. I have a large lawn tractor that I use to mow my three and a half acres and an older garden tractor that I use for various utility duties. These suit my needs very well at the moment. This is all my opinion based on my personal experiences. Your mileage may vary. :biggrin:
