- Nov 29, 2014
- 64
- 24,702
The pins do not control the brake they control the bypass valve between the pump & motor .
The brake is a toothed plate which engages with a toothed wheel on the side of your transmission
Here is a little video that explains how it works
Toro brake module
Now as to your bypass valves
When there is no load on the wheels some oil will go through the motors so on a jack the wheels will spin, pins in or out .
Having said that the control rods are thin & do bend so check that the lever on the side of the box that you keep on thinking is the brake ( which it is not ) moves to the end of its travel, if not then straiten or bend the wire as needed .
To disengage the brake manually you have to get under the mower and remove the brake rods from the brake module .
The brake is on the INSIDE of the transmissions wher the arm you are playing with os on the OUTSIDE of the transmissions.
The instructions for doing this are in your owners manual.
If you have lost yours then it is a free download from Toro but you will need the numbers off the mowers ID tag to make sure you get the correct one .
Toro brake module
