2013 Toro MX5060 (50") zero turn. It doesn't matter if the pins are pulled out or pushed in, the machine still moves. It doesn't seem to disengage the transaxle for manually pushing the mower. For mowing, the machine works fine.
Today I tested to see if the machine would move with the pins pushed in. I pushed the pins in on both sides, started the mower and could drive it same as I've always done. I then pulled them out as they should be for driving. A long time ago I suspected something was not right because its very hard to push manually. Pushing it manually is the only time this matters. Otherwise it moves as it should when mowing. But the pins (both sides) do not appear to be disengaging the transaxle. What's wrong here? Expensive to fix ?
