FredBacher
Unless I've missed something along this discussion, the blower runs fine as long as the air isn't restricted, correct? It idles fine. Sounds like it blows pretty hard.
Yes, 100%. Starts up after a pull or two, will idle all you want, and the air will blow when the trigger is pulled. You can even walk around with the blower blowing things and you'd think it was fine. As soon as anything goes over the air intake though, it dies.
Did you peak inside the ports to see if their was any cylinder scoring?
Is there any build up of oily dirt coming from behind the flywheel?
Ports? Which ports should I be looking at? Like on the carb itself?
I didnt see any dirt from the flywheel or anything behind it. Flywheel is the part the starter cable hooks up to, right, with the magnetic metal round arms that spin when you pull?
