PTmowerMech
- Apr 16, 2018
- Threads
- 397
- 3,030
Sorry. Work got in the way.
As of today, new starter and solenoid. If I jump the solenoid the starter will crank the engine.
But, the starter will not engage using the key. If I turn the key the oil light will come on, the headlights work, and the PTO will click on and off.
If I turn the key to the start position the dash light comes on indicating that the brake pedal needs to be depressed. If I depress the pedal the light goes off, but the starter does not engage If I turn the key to the start position.
Could the switch be the culprit? Should I try jumping the leads from the switch to the battery end of the solenoid?
You absolutely checked the fuse, right? If you can't see a broken link, check it with a meter anyways. Sometimes they break on the sides, and not the middle, where you can't actually see the break. I've spent 4 hours on a mower on day trying to figure out why I was not getting juice to the starter. Checked the fuse a few times before I finally broke down and checked it with the meter.
