Oil coming out fuel pump
kjonxx
Rings could have lined up where end gaps are all in the same place. Heard of that happening after oil change. Makes no sense tho.
Red Good
Well. Not sure but i almost mowed the entire lawn before the motor stopped with some smoke, more stalled but fuel pump still spit some oil. I would guess I mowed 25-30 minutes. Not ready to call it rings, it just starts and runs too good. I will have to pull the valve cover and give a more detailed look with a flash light. Crazy that this just started pretty quick (problem)
Why did it stall ? out of gas or fouled the plug ? Were you still mowing when it stalled ? Tall grass over loaded ?
Olrecker
Too much oil going into the intake, i wasnt mowing, i shut off the deck when it started running poorly, last minute or two. I cut with my other tractor a week earlier so barely needed cutting
kjonxx
Sounds like maybe oil filled fuel pump to the point it could not pulsate
Six pages now. Is this running proper yet?
Olrecker
No but thanks for asking. I am busy with main transportation and the holidays. Maybe I can haul it into the garage for the long needed compression test. Avoided it as it starts and runs great until the oil pressure into the carb knocks it out
