Why did it stall ? out of gas or fouled the plug ? Were you still mowing when it stalled ? Tall grass over loaded ?Well. Not sure but i almost mowed the entire lawn before the motor stopped with some smoke, more stalled but fuel pump still spit some oil. I would guess I mowed 25-30 minutes. Not ready to call it rings, it just starts and runs too good. I will have to pull the valve cover and give a more detailed look with a flash light. Crazy that this just started pretty quick (problem)
Too much oil going into the intake, i wasnt mowing, i shut off the deck when it started running poorly, last minute or two. I cut with my other tractor a week earlier so barely needed cuttingWhy did it stall ? out of gas or fouled the plug ? Were you still mowing when it stalled ? Tall grass over loaded ?
No but thanks for asking. I am busy with main transportation and the holidays. Maybe I can haul it into the garage for the long needed compression test. Avoided it as it starts and runs great until the oil pressure into the carb knocks it outSix pages now. Is this running proper yet?
